I went digital wherever possible. Digital table saw fence, digital height gauges, digital calipers, digital planer gauge, etc.
I also realized many, many, years ago that in most cases of woodworking, that the dimensions aren't all that important, if you realize that many woodworking chores require two of each, so making two at the same time and with the same machine setups makes two parts that actually are the same dimensions, but maybe aren't exactly to some desired plan dimension. For instance, when making a box = two short sides - a left and a right, two long sides - a front and a back, and two ends - a top and a bottom, although sometimes the top and bottom are different by plan, but then they don't have to be the same. You can carry this pairing to other projects - 2 rails and two stiles for a door, etc. The overall dimensions may vary slightly, but keeping your pairs of parts accurate to one another makes projects go together very well, even if their overall size may not be perfect to plan.
I have the greatest problem when I discover that after I have completed a project, that I have to make another one "just like it". I could have made two at the same time (4 of each part), but now I have to repeat the setups and get them the same as when I made the first. I can get close, but almost never,"exactly the same".
Charley
