When I was a youth, I was an amateur magician, and though never a great performer, I've always kept up a scholarly interest. One of the old, classic effects is a production-box known as a "Square Circle".
These tend to be from the "gaudy box" school of magic, which was rejected by the celebrated 19th century French conjuror Jean Eugene Robert-Houdin, in favor of apparatus disguised to look like recognizable, ordinary objects.
This is an attempt to do the same with this classic piece of illusion apparatus:
I decided that an old-fashioned animal cage would do the job, and the style was inspired by the hilarious animated feature "Madagascar". Sides, back and top are 1/4 birch ply, with 1" strips of 1/4" poplar to give the "crate" look; the ply has been scored with a V-tool on the router-table to give the "built-up" look.
Interior is lined with black felt, and top and bottom painted flat-black, to hide the "modus operandi". The bottom is 1/2" birch ply, as it is not an appearance item.
The box is about 8" square, to match the proportion of a standard #10 "tin can", which would be used along with this prop; it would be placed inside, after showing both box and cylinder empty, and goods are then "magically" produced from the apparatus. A tin-can was chosen for the cylinder as it meets the definition of "recognizable ordinary object".
The face-frame is 1/2" poplar, and the door 3/8". Holes for 3/16" dowels were drilled, then the door laterals were grooved on the TS, with the verticals getting a tongue for assembly.
This will be put up for sale at our local magic shoppe.
Regards, John
Regards, John
