So how much do you need? And how set on just that pattern are you? If it's not a tremendous amount that would take hours to do, I have an Air Conditioned Shop, a router table and a lot of pattern bits. I also have a lot of leftover maple stock.
I can't volunteer yet, until I know the magnitude of the work, but I might be able to help you out.
That pattern might actually be easier to make as two pieces glued together. The top is almost a double ogee and the side piece would then be a simple cove bit. Doing it that way I could probably manage with the bits that I already have.
My shop is somewhat cluttered at the moment so I only have limited infeed and outfeed room on each side of the router table which will limit long runs of stock.
- Ken.
