If you've never tried, but wondered about the process, here are a couple of pics from a current project.
Lovingly referred to as a "Mariach-ulele", this big-bodied Ukulele features an 18" scale, One-piece maple neck, walnut back, mahogany sides, spruce top, and rosewood fretboard and embellishments.
The neck and and body were built separately, and are just about ready to get put together.
In the first two pictures, I was working out a clamping setup before I needed it. I need to glue and clamp the fretboard to the body while pulling the heel of the neck into the body. I put a couple of pieces of Purple Heart and some pipe clamps into play to pull it off:
Next, I needed to install the frets, which I rough-cut to allow them to be easily aligned and tapped into the slots I cut earlier. Once they are firmly seated, I snipped them close to the fretboard with flush-cut snips.
After they were close enough, I grabbed a palm-fitting file to bevel and smooth the edges for easy playing.
i glued the rosette in place (the only piece I did not build) while installing the frets, so I was anxious to see how it would look, so the final photos are a mockup before putting this thing together.
