LED Shop lights
PhilErup
PhilErup
That's a fantastic deal on shop lights! LED lights are good because they save energy and last long. I got some for my workshop, and they're bright, which is excellent for working on stuff that needs a lot of light.
When picking LED lights, you've got to think about how bright they are and what kind of light they give off. I learned a bunch about this from LED LIGHTING - world's #1 led lighting review site. They have articles that help you determine which LEDs are best and where to buy them. I bought some LED bulbs for my garage from there. They're perfect and only cost me about $25 for several bulbs.
mpholway
Board of Directors, Events Director
I am looking for recommendations as I am about to replace all (12) of my 4' fluorescents. I am going to replace the fixtures. I do not want to just replace the bulbs.
Wiley's Woodworks
Wiley
Hey Mike--This looks like a "devil is in the details" deal. 2000 lumens per fixture is dim lighting. When I replaced my shop fixtures, my electrician installed 5000 lumen/natural light fixtures. At any price these might not be significant upgrade. A lighting expert can explain the difference in actual use. Just because it's LED doesn't make it bright.
I used them in a few dark corners of my shop. Not my main lighting.
That was almost two years ago, they are long gone by now.
5000 lumens for one bulb?
Wiley's Woodworks
Wiley
My fixtures are twin bulb, small tube, no cover. They are mounted flush to the ceiling rather than hanging from chains. I have both 4' and 8'.
So, 2500 lumens per bulb, 5000 per fixture. The 2000 lumen bulb I bought for a dollar is not that bad.
Yes, it is less. but for spot light in a smaller area over the lathe or under a cabinet it works fine.
golfdad
Co-director of Outreach
Dirk
I use 6000Lum LED bulbs in the shop . These are replacement bulbs the plug into the old style fixtures. Less than 10/bulb from Green Light Depot
NCJim
All my overhead lights are LED, two are set in a motion mode so when I go into the shop two lights come on. These were two tube lights purchased at Walmart for $10 each. Still working after a year or so in use.
Ricksmi
Rick
Each of my shop lights (12 total) are (single LED tube) are 5000 Lumens each from Rockler years ago with specific spot lights at the band saw, router table, and lathe where extra light is never enough. But I still have a "shop" light or bulb in a cage in the garage (1960s) for looking under the hood and upgraded it to a 60watt led.
I thought this info may be useful to some.
ABOUT 4FT LED TUBE LIGHT FIXTURE | 4FT LED BULBS​
Buy the best quality 4-foot LED tube lights from LEDMyplace to have a better indoor lighting experience at a low price. These UL and DLC-certified LED tube lights are the guaranteed and energy-efficient replacement of fluorescent tubes.
When you need a certain smaller size of the tube, but at the same time pack a luminous punch, the T8 4FT LED tube light becomes the perfect choice. Having the ideal size for a small installation, the T8 4FT LED tube lights are a great example of how size does not matter.
The T8 4FT tube is an ideal fixture for your residential or commercial application. The tube skillfully replaces the 4FT fluorescent lights and gives an unmatched advantage over its predecessor.
Most T8 4FT LED tube has a single-ended base which means that the tube draws power from one end only where both live and neutral terminals are situated. The other end of the tube is only for support. More information about single-ended or dual-ended LED tubes can be found here.
Further, Ballast is compatible with some T8 4FT LED Bulbs whereas it is not compatible with some. Ballast is a component that was used by a fluorescent tube to start. It used to be an essential component of the tube light fixture.
In case the LED tube supports a ballast, the tube can be simply installed. But if the tube does not support a ballast, then the ballast will have to be either removed or bypassed. Further information on how to bypass a ballast can be found here.
TYPES OF 4-FOOT LED BULBS
There are three kinds of 4-foot LED tube lights available: Ballast Compatible, Ballast Bypass, and Hybrid. The simplest to mount is compatible with Ballast. Make sure that the compatibility of the ballast is tested to ensure that the ballast is compatible. As the name suggests, Ballast Bypass is the removal of the Tube lights from the Ballast. This decreases the treatment of the ballast. These fixtures are available in single-ended and double-ended models as well. Does the query now arise as to what is single and double-ended? Single-ended fixtures only require power at one end, and power at both ends is required for double-ended fixtures. The third is the Hybrid, which is a mixture of Ballast and Ballast Bypass compatibility.
Let’s understand this a bit more and binge into it:
  1. Ballast Compatible
The simplest and fastest way to choose LED fixtures that will offer more quality and energy-efficient lighting is Ballast Compatible. You can easily remove your fluorescent tube and insert it into the newly purchased LED fixture by selecting a ballast-compatible tube for your fixture.
But there are several drawbacks associated with Compatible Tubes for Ballast:
  • The ballast can fail and you will not be able to use your tube after that.
  • The ballast requires some energy to work, making it excessively expensive and less energy-efficient.
  1. Ballast Bypass
Ballast Bypass is the most trustworthy and promising solution you will take with you in the future. By bypassing the ballast, you will save the excessive wattage used by the ballast, and if the ballast fails, you will not have to rewire the tube.
If we speak directly, you can save 43 kWh per tube per annum by bypassing the ballast. If you use tubes on a large scale, it is possible to save 1000+ kWh of electricity.
Bypassing a ballast is a fairly easy operation, but we suggest a licensed electrician before doing any wiring-related work.
  1. Hybrid
As it works for both types of installations, the hybrid option is the most versatile to choose. This means that you can either opt to mount the tube with or without the ballast. In other words, even after the ballast fails, you can use the pipe.
TIPS FOR CHOOSING 4 FOOT LED TUBE LIGHT
When picking your 4ft t8 LED bulbs, make sure to look at the color temperature and the ratings and certifications. The temperature of the color represents the light color and is measured in Kelvin. 4ft LED Tube light in the Kelvin range of 3000 to 3500 creates a friendly environment suitable for lobbies and waiting areas. In offices, schools, hospitals, and warehouses, 4000 to 5000 Kelvin tubes can help minimize eye strain and improve visibility. Ratings and certifications reflect the kinds of situations in which the tubes can be used safely. Tubes rated for dry areas can only be used indoors where the tubes do not contact with water or humidity.
ADVANTAGES OF USING T8 4 FOOT LED TUBE
Energy-efficiency: The biggest advantage perhaps of using LED products, the efficiency of these tubes is off the charts. LED tubes convert 95% of the electricity into light and only 5% of the electricity is wasted as heat. This translates into a highly energy-efficient tube light that replaces a higher-power fluorescent light.
This also brings good news for the environment as when less electricity is consumed to give the same amount of brightness, fewer fossil-fuels are burnt and fewer greenhouse gases are released.
Long-lasting: The LED tube lights 4 foot have a long life and last for more than 50,000 hours which means that once you install these LED tubes you won't have to worry about replacement or maintenance for at least half a year.
High CRI: The CRI or the color rendering index measures how accurately a light renders colors in comparison to an ideal light source such as the sunlight. The CRI of T8 4FT LED tubes is more than 80 which means that the colors rendered by this light are 80% accurate as compared to daylight.
SOME MAIN TECHNICAL CONTEMPLATION
Types of Connections
  • Single Ended
One pin attaches to the line and one to the neutral, electrically attached from one end of the tube. Non-shunted sockets and rewiring are required for this type.
  • Double-Ended
On both ends of the tube, with one end leading to the line and one to the neutral, electrically attached. This form may use sockets that are shunted or non-shunted. As they replace the original bulbs, one end of the tube connects to L and the opposite end to N. One end should not be connected to both.
COMPATIBILITY OF BALLAST
  • Ballast In-Line
Installation of Dual-End Type A is "Plug and Play" and essentially replaces the original fluorescent tube with an identical LED, requiring the original ballast to be used. If you have already decided that your ballast is working properly, this is the best solution for re-lamping your fixture.
  • Ballast Bypassing
Single-End Type B installation requires bypassing the original ballast and rewiring sockets (tombstones) in the fixture. This is a popular solution when re-lamping due to the likelihood of an eventual ballast failure.
WIRING OF SOCKET
  • Shunted
Both contacts are linked/bridged in the same socket (tombstone) and have the same polarity-either L or N. Connecting the two pins of a shunted socket will generate a light ring in the voltage meter that represents electricity flow.
  • Non-shunted
Contacts in the same socket (tombstone) are split but can be either the same polarity or opposing polarity, depending on how the socket is wired. Direct wire-led tubes use a non-shunted tombstone as a thumb rule. In the case of a T8 substitute, bypassing the ballast might be necessary, making it mandatory to use a non-shunted tombstone.
Still, if you are confused about choosing the right tombstone, you can prefer our Tombstone guide.
FREQUENTLY ASKED QUESTIONS
Q: Do 4FT LED tube lights emit heat like traditional fluorescent tubes?
A:
4FT LED tube lights produce significantly less heat compared to traditional fluorescent tubes. LED technology converts more electricity into visible light rather than heat, resulting in a cooler and more comfortable lighting environment.
Q: How long do 4FT LED tube lights typically last?
A:
4FT LED tube lights have an extended lifespan, usually lasting up to 50,000 to 60,000 hours or more. This longevity ensures reduced replacement and maintenance costs.
Q: Are 4FT LED tube lights compatible with existing fluorescent fixtures?
A:
Yes, many 4FT LED tube lights are designed to be compatible with existing fluorescent fixtures. They can be easily retrofitted into the fixture by bypassing or removing the ballast, ensuring a seamless transition to LED lighting.
Q: Do 4FT LED tube lights produce any flickering or humming sounds?
A:
No, one of the advantages of 4FT LED tube lights is their flicker-free operation. Unlike some fluorescent tubes that may flicker or emit a humming sound, LED tube lights provide stable and quiet illumination.
Q: Can 4FT LED tube lights be used for task lighting or general ambient lighting?
A:
Yes, 4FT LED tube lights are versatile and can be used for both task lighting and general ambient lighting. Their bright and uniform illumination makes them suitable for various applications, from illuminating workstations to lighting up larger areas.
Q: Do 4ft LED bulbs need a ballast?
A:
Some 4ft LED bulbs are designed to work with existing ballasts (plug-and-play), while others require bypassing or removing the ballast (direct wire). Always check the manufacturer's specifications to determine the appropriate installation method.
Q: How much watts is 4-foot LED tube?
A:
A typical 4-foot LED tube ranges between 15 to 25 watts, but the exact wattage can vary based on the manufacturer and model. Always check the product specifications.
jgt1942
imho, the brighter the better. Bulb temp is critical, get what they call daylight, this is a temp of 6000k to 7000k. If you go too high it will get blue.
I'm attaching my lighting journey
  • Lighting Journey JGT.pdf
cyclopentadiene
Unfortunately they last the same amount of time for me as traditional. My shop ceilings are 8’ and I tend to hit the lights with lumber and break them far before they meet their lifetime.
However LED are much brighter until I do bust them.
bowman
Board of Directors, Webmaster
Neal
At least there is less thin glass slivers to clean up when that happens
mkepke
FYI, Ace Hardware has 4' Feit LED replacement tubes on sale for $9.99 for a pair. These are not high output tubes, being ~1850 lumens. I just bought a couple pairs as a test-run to replace the dying fluorescents in the garage, so no review yet.
My shop lighting is still chugging away using those 4' troffer lights courtesy of Phil so many years ago - with the original tubes. (Thanks again Phil!)
Thanks to Mike for alerting me to the existence of "hybrid" LED tubes. If I can avoid standing on a ladder to rewire a bunch of overhead troffers I will.
-Mark
peltona
Andrew
I have had good luck with Lithonia LED fixtures. I prefer the models that you can adjust the Lumen and Kalvin outputs. I originally thought I would like the 5K but later was able to just adjust them to 4K. The 5K was a little hard on the eyes and it was good to have that adjustment capability.
old-delta
Wes
Interesting topic. I have 4' and 8' fluorescents in my shop I'd like to convert to LED. Only due to the fluorescents being faded out in the market. With 80' of 8'ft and 60' of 4' I may have to get a second mortgage lol
JRedding
I’m also using 8’ Lithonia LED with 5000K color - it’s bright, but that’s what I was looking for. I have 2 rows spaced every 4 feet (both within a row and the distance between the rows) so I don’t have many shadows. I think there are 18 of them (I forget at this point and didn’t go out there to count).
