Leather care for a writer's desk blotter
dwhitener
Daniel
Hello all. I'm nearing completion on a contemporary writer's desk shown in issue #270 of fine woodworking. Instead of a wooden desk surface, it's covered by a large leather blotter. I have never worked with leather before but I'm hoping some of you surely have some advice for it. It calls for a 10-12 oz weight leather - it's thick. I bought one described as "9-10oz full grain oil tanned cowhide". If you thought lumber was expensive, check out the cost of 10oz leather... I'd really like to NOT mess this thing up!
My leather-related questions are these:
1) The leather looks a tad dry and lightly scuffed from handling... If this leather were on my black dress shoes, I'd break out some shoe polish and shine them up a little. What sort of treatment should I use for this blotter/writing surface to refresh it? I've seen a variety of oils, conditioners, etc.. out there on the market but I am clueless where to start or how to chose which one for this application.
2) The edges of the leather need to be turned down a bit to hide the cut edge. People on the internet are able to shape their edges seemingly easy. I have a bone creasing tool, but it's not working. I suspect it may be because this leather needs a little moisture in it. Do I need to somehow wet the edges before working them or will the above suggested oil/conditioner help with this process?
Thanks in advance
Daniel
Don't know- except watching my brother and his wife do turns in leather.
They would make a small "U" then thin the area a bit, then get wet then heat iron the top and use duct bending pliers (duct seaming pliers) and work away.
Should have paid attention more
ptt49er
Phillip
Bringing one up from the past.
Any chance you're still kicking around Daniel? How'd the desk turn out? It looks like it would be beautiful!
Wiley's Woodworks
Wiley
To address the scuffs spread out the leather and give it a good cleaning with saddle soap. Stretch it by hand while it's wet. Then put a towel under it and let it air dry. It will be a lot easier to work, and the surface probably will turn out more uniform. Use spray can contact adhesive per instructions to attach the leather. Google search for a skiving knife to thin/bevel the edges so the leather doesn't stick up proud of the desktop wood. Practice with the knife on scraps.
old and in the way
tone
Daniel:
Much as some people discover that buying lumber does not mean that they have the skill to create furniture, so it is with many endeavours. When you get to the point where you discover that working leather is truly its own craft, you may want to get in touch with these guys:
Leather desk tops
I don't want to sound harsh, but over the years I have learned some things the hard way.
Hope this helps.
Tone
