KREG PRECISION PRS1040 ROUTER TABLE - $400 (RDU Airport Area / Brier Creek)
Splint Eastwood
Date: 2010-02-20, 2:55PM EST
Reply to: sale-hcj48-1609949282@craigslist.org [Errors when replying to ads?]
Selling Brand New KREG PRECISION ROUTER TABLE (24 X 32 inch table top) for only $400.
Compare to over $500 online and OVER $799 RETAIL.
Model PRS1040
Fully-Enclosed Self-Squaring Fence Travels Parallel to Miter Slot
Precision Lens Cursor Offers Incredible Accuracy Without a Tape Measure and Pencil
Professionally Edgebanded, Steel-Strut Reinforced MDF Top
Impact Resistant Easy-Slide™ Micro-Dot Skin
Phenolic Insert Plate (9-1/4” x 11-3/4” x 3/8”)
Dual Reducing Rings (2”, 1-13/64”) Feature Porter-Cable Guide Bushing Compatibility
Unique Bottom-Up Levelers Feature 8 Individual Contact Points for Leveling Accuracy
Independent Fence Faces Allow the Table to Double as a Vertical Jointer
Custom Insert Plate Drilling Program Available, for details Click Here.
Patent Pending
From the Manufacturer
Whether you’re routing a simple dado, putting the finishing touch on a countertop, or building an entire set of raised panel doors from scratch, the Kreg PRS1040 Precision Router Table helps woodworkers of all levels finish projects faster, easier, and with greater precision than ever before. Taking design cues from high-end table saw rip fences, the Precision Router Table Fence features a t-square style design which keeps the fence permanently parallel to the miter slot. This automatic squaring lets you fully utilize your miter slot and makes it easier than ever to make small adjustments on the fly. The fence is made from an incredibly rigid fully-enclosed aluminum extrusion which helps support even the largest workpieces, while also helping to create a full length vacuum chamber for superior dust collection and a cleaner shop. The fence also includes two fully independent fence faces, allowing the router table to double as a vertical jointer. The Table Top of the Precision Router Table is made from a vibration and noise resistant MDF which features an Easy-Slide™ Micro-Dot skin – constructed from a high-pressure laminate – which makes it easy to slide workpieces across the surface. The durable MDF top is even reinforced by two steel support struts which keep it from bending or bowing over time. Made from an incredibly durable phenolic, this standard sized insert plate (9-1/4” x 11-3/4” x 3/8”) has been designed to mount to any router without the usual ‘swiss-cheese’ type surface found on most router table insert plates. Utilizing your router’s base plate and the easy to use template (included), mounting the insert plate to almost any router leaves you with a perfect custom fit and without all of the extra holes you don’t need Dual reducing rings (2”, 1-13/64”) boast three independent leveling/lock-down screws.
Product Description
Whether youre routing a simple dado, putting the finishing touch on a counter top, or building an entire set of raised panel doors from scratch, the Kreg Precision Router Table  through a series of innovative new features  helps woodworkers of all levels finish projects faster, easier, and with greater precision than ever before. A quality router table is one of the most important tools for any serious woodworker to have around the woodshop. The Precision Router Table Complete, 24" x 32" boasts an incredible feature-set and brings a whole new level of rigidity and precision to your woodshop.
  • it's NOT ok to contact this poster with services or other commercial interests
PostingID: 1609949282
bbbbbbbbbbbbbb
