Hey guys,
I have an older Jet jointer I am working on cleaning up. I started by getting some new Freud knives for it (found them cheap on Amazon and they had better reviews than the Jet ones).
Next I went to install the new knives and discovered that 2/12 screws holding the cutterhead knive plates had become wedged tight with pitch and sawdust and stripped as I tried to remove them.
After getting everything apart, I decided the cutterhead itself had probably never been cleaned and it might be a good idea to take it out and give it a little TLC.
Here came the big problem. This is an older model Jet (before the blue paint scheme even) but it is almost identical to the current models as far as assembly and parts goes. I made it mostly through the (current) manual as it described how to remove the cutterhead and realized the bolts holding the cutterhead to the base fall down through the base. The manual describes the bolts in the current model as screwing upwards into the cutterhead being held tight by a locknut.
So...it looks like on this older model, the only way to remove the cutterhead is to take the entire machine apart! I can't verify, however, because I do not have the original manual and don't know where to find it. You NCWWs could do me a huge favor by helping me find:
A. The original manual or
B. a replacement cutterhead that will never make me take the machine apart again or
C. replacements for the 2 or 3 damaged plate screws...
Keep in mind I bought this older, used machine because my budget isn't super high, so paying $200 for a nice, new cutterhead would almost be like paying double for the machine....
