Interest in standing or fresh sawn oak lumber?
jpaul
I have some fairly large oak timber on my property and a lot of it is in the way of where I want to put my shop. Others are just too close to the house and need to come down. I have talked to a few loggers but I don't have the quantity they need to bring in their equipment and I really don't want the whole place clear cut. I also have about 5 acres of set pines that are about 25-26 years old that is past needing thinned but again it's not worth their time.
Anywho, all of them obviously are more interested in the hardwood vs the pines anyway. I got to thinking if I could find a buyer(s) for the hardwood then I would find someone with a sawmill to make it into lumber. I would like to keep it for myself but I don't have the place to store it and I need it to fund the building.
My question is, does anyone here have any interest in lumber while it's still on the stump? I don't know exactly what all kinds of oaks they are, but according to the leaves there is probably at least 3 different kinds out there. Some of the trees are in the 24" diameter range, some are smaller.
Thanks for your input, and any suggestions you may have.
Here is a basic for calculation on log length and diameter.
Standing tree calc would be less than what I am listing below. But just for reference:
12" log 12' = 50 bd.ft.
16" log 12' long = 105-110 bd.ft.
20" log 12' long =195+/-
24" log 12 long = 300 bd.ft. +/-
Remember this would not take into account the bark thickness.
Good luck.
DSWalker
I'm too far away to be interested in the lumber, but do have a suggestion for the lumber.
I had a pole barn type shop built a few years back using 6"×6" poles. They installed the exterior siding, but left the interior unfinished.
I cut a bunch of pine from my property and had a mobil sawmill come out to mill it. I only had 1"×8" × 12' and 2"×4"×12' cut. I let it dry while they were building the shop, and then framed up with the 2x4s in between the 6"×6" posts. I then used the 1x8 boards for my interior walls. Spent $500 for the milling work and have a bunch of the lumber still left for odd projects as needed.
jpaul
I'm about an hour south of Asheville.
I have 5 acres of pine pulp that is still on the stump, but it's not ground up yet. But thanks for your input, it was most helpful.
I hope that that helped. You may need to get a consulting forester to figure out what your trees are worth. Call the Agricultural Extension Office in your county and they'll put you in touch with foresters.
