Insulating Roof
mike_wood
I am to the point of considering how to insulate my new shop. It is a 1.5 story structure and I am considering extending the insulated area to the upstairs storage space in order to mediate temps up there. I had a spray foam guy out today to give an estimate. When we discussed the roof insulation he said there was no need to put baffles for venting. I have always been told to vent insulated roofs to protect the shingles. His comment was that without baffles the shingle life may be reduced by 2-3 years but shingles usually don't last as long as claimed. My shingles are 30 yr Owens-Corning and they say to put the baffles.
Suggestions appreciated.
FredP
Fred
yes to baffles. it is my understanding that not only does the baffle allow the roof to breath but it also creates air flow to dry condensation on the nails that protrude through the sheathing. the nails condensate from changes in temperature and without the airflow to dry them they will remain wet causing the sheathing to rot. I may be wrong but I would err on the side of caution.:dontknow:
MrAudio815
Matthew
I love this site,
Good info at every turn. I don't need this info now, but hey you never know when you'll need some info.
Thanks for the question and answer~!
scsmith42
Scott Smith
You can go either way. The last roof that I spray foamed had the foam sprayed directly on the underside of the roof. The nice thing about this is that it keeps all condensation from forming on the lower side of the roof.
gdoebs
Geoff
I know I've seen spray foam applied directly to the sheathing with no baffles. You could always call Owens-Corning and ask them about spray foam.
crokett
If you have spray foam you do not need venting, or at least you do not need the styrofoam channels. The venting keeps condensation from building up in the air trapped between the batts and the roof. With spray foam it is directly on the roof deck so there is no air between the insulation and the roof decking.
mike_wood
I understand about the moisture but my concern was about heat buildup since there was no way to dissipate it. Whatever happens it is too late now as it was done last Friday. It looks good and I can already tell the difference. Sunday was warm an normally the attic would get pretty hot as one sides faces SW. We worked up there all day and it did not get over 80. We'll see as I am putting in a mini-split HVAC on Tue.
Thanks for the comments.
Mr. Bill
Bill Hinds
Mike, I'm considering doing the same thing. Can you give me an idea of cost? Per sq foot of roof would work, I don't want to get nosey:gar-Bi
mike_wood
It's pricey but worth it to me. Count on $1.25/ft2 for walls and $1.50/ft2 for the roof as it goes on thicker. I like how it fills all the voids.
Let me know if you have any more questions.
scsmith42
Scott Smith
The "R - value" scale does not accurately depict the efficiency of spray foam. For one thing, it creates a total vapor block so that you eliminate all drafts, etc. It is incredibly efficient.
Depending upon if it is open cell or closed cell foam, as well as the application depth, it can offer equivalent R-values up to R50.
mike_wood
Open cell foam is about 4/inch. But as indicated before that does not tell the whole story. Just looking at it I can see how much better it is than standard insulation.
Also when considering cost you get a 30% tax credit (credit, not deduction) from the feds and I think from NC too. I know NC passed some tax credits for energy savings (eg. geothemal heat pumps) but not sure of insulation. So if you put it in this year or next you get 30% off your taxes up to $1500. This is one of the reasons I did it.
mkepke
?? This is like saying you can't compare the MPG of a Honda and a Lexus because the Lexus comes with extra cupholders.
R-value is a standardized measure of thermal resistance under specific conditions...and it's used by the foam manuf. to rate their products.
I think it's understood that spray foam has more advantages than simple R-4 per inch. Otherwise who would buy foam given the price ?
Mike - NC does not offer insulation credits that I have found, but your utility might give you something. Progress Energy (electric co) offers up to a $300 rebate if the work was performed by an approved contractor (no DIY allowed) - some other restrictions too (not sure a non-primary dwelling qualifies).
-Mark
mike_wood
I have already collected $600 from Progress for geothermal heat pumps. Considering the relative cost of geothermal heat pumps and insulation I don't think any rebate from Progress would be worth the stamp. But I will check. Thanks.
scsmith42
Scott Smith
-Mark
You mean that cupholders don't impact fuel mileage???? What about whitewall tires??? :gar-La;
I should have been more descriptive in my comments about the benefits of spray foam, but I was rused at the time I typed it. That'll teach me...
mkepke
Sorry..probably over-rotated a bit in my reply too. :slap: <--me
And I'm still hoping for word on how much foam Mike had sprayed in.
-Mark
mike_wood
As to how much insulation, the 2X4 stud walls (in hindsight I wish I had used 2X6) were overfilled then cut off level. The 2X6 roof was overfilled by ~ 2" (this is why the roof is more expensive). The gable ends are ~2.5". The installer caulked every inch of the top plate and any other gap they saw (e.g. the walls sit on a 2' brick wall - they caulked all the way around it). They put low expanding foam around the doors and windows (I have one double door and one standard door, one standard window and four small windows close to the ceiling on the sunny sides of the shop). I am really trying to get a tight building.
My mini-split HVAC goes in on Tue (it qualifies for a tax credit too!) so I am anxious to see if this approach pays off. I have not insulated the ceiling yet. I want to see if I have to when it gets a bit colder. I would prefer to leave the ceiling open so I can run wires and, when I can afford it, dust collection piping. The HVAC is a little smaller than the space calls for so I may be forced to insulate. Once it gets really cold I will find out.
mkepke
<snip>
Thanks for the info. I have a couple 'cold' spots in the house I was thinking about retrofitting with foam..awkward spaces that were not (cannot be ?) FG batted properly.
Coincidentally, my shop is also 1.5 stories and I too just bought insulation, but went with traditional FG batts. Was planning to use cellulose, but couldn't pass up the killer deal at HD/Lowes. Does mean I get to spend time with vapor barriers and getting covered with glass fibers tho.
I would love to hear more about your mini-split (what you bought, where you're putting the blower, cost, etc..how it performs) as I was planning to turn the upstairs of the shop into a stained glass room for my wife and a playroom for the kids. Was thinking about a small split system or a mini-split with two blowers (two rooms) as it would be quieter and have better distribution than the through-the-wall AC I have in the downstairs part of the shop.
Cheers,
-Mark
mike_wood
The mini-split system does not have an air handler like a traditional heat pump. Is that what you are asking? It requires a 3" hole in the wall, one of the attractions for me, and the unit on the ground is very small and contains a fan. Another advantage is that it only requires a 110v 15A hookup. I had planned to put in a through-the-wall heating-cooling unit that looks like a big air conditioner they sell at the Borg for ~$500. But I could only find a unit with a SEER of 9 or so which made me reconsider my approach. After reading about the mini-splits (with a SEER of 16 or so) I decided that perhaps in the life of the unit I would at least break even and get better service. Sorry to keep repeating this but the 30% tax credit had a lot to do with my decision here too.
I priced out regular insulation with me installing it which was especially attractive with the current sale at Lowe's. But as it turns out, the foam will cost me ~$900 more. I thought the advantages outweighed the extra cost. Not to mention I was not looking forward to putting in insulation, one of my all time disliked jobs.
After it is installed if you want to look at it let me know.
BTW, you can get the tax credits for regular insulation too.
mkepke
<snip>
Yep, I know.
I decided that for $0.16 per square foot for R-30 (after fed credit), I could live with the itch. :eusa_danc I sprang for some Tyvek hooded coveralls - should help.
At least I hope it does because I have 2000 square feet to install.
-Mark
