I have used quite a few yonico bits, both the inexpensive large router bits like this as well as the solid Carbide endmills. Somehow Amazon put a lot of 1/2 shank size 1/4 cutting diameter solid carbide compression bits up for $2 apiece last year and I bought a lifetime supply of them...
I've never had any problems with yonico, no worse than any other comparable Chinese bit seller, which is to say totally acceptable.
My lock miter bit is pretty cool although setting them up is always a chore. I think they make setup blocks now although cutting a properly set up section would probably yield you the same thing.
