I Know I've Seen One, But
gator
George
I can't find the style lock I'm looking for. Picture the handle/lock on a P/U cap. You twist the handle and there are two bars that extend into the sides and lock the door shut. I have seen this on a smaller scale with a key that you turn, as in a regular lock, for furniture. Basically, you turn the key and the bars extend into mortices on the sides of the opening, pull the key out and the door/panel/drawer is locked. Turn the key and the bars slide back towards center thus freeing the door/panel/drawer to open. I can find the 'rotating' bars where the bars rotate and have a hook at each end that goes around a little peg. This won't work for me. The application I have in mind has to have the sliding/extending bars that go into a mortice. Any good memories out there of where this might be found?
George
chris99z71
Something that looks like this, George, but with just a simple, semi-flush key lock cylinder instead of the T-handle?
yhst-37697109791737_1944_193024928
gator
George
Chris -
You described it to a "T". Needs to look nice on a small (36" wide x 36" high) bookshelf type piece. If I find the lock, I will probably sandwich it between two boards to hide the mechinism except for where the ends of the rods come out.
Round rods would be preferable but flat bars will work too.
George
I have seen them on garage doors. I would think agrisupply would have something like that or be able to tell you where to get it.
chris99z71
OK, here's a lengthy idea...
Check this out.
http://www.prime-line-products.com/catalog/s.pdf#page=18
I was specifically looking at the "drawer and cabinet locks" if you scroll down 1 page.
Home Depot caries the Prime-Line brand products. They're on a display in the aisle with the cabinet hardware and they're carded products with packaging that look like this:
You could make your own piece that goes on the back along with your own rods and guides (for the far ends of the rods) out of brass. It's just a simple piece of flat stock with a square hole that goes on the back.
DavidF
George
http://www.rockler.com/product.cfm?page=10064&filter=cabinet locks
You could maybe make your own extensions for 47310 model.
