How to antique hinges?
David Turner
I am finishing up my John Townsend bureau by installing the brasses and need to age a set of bright brass hinges that go on the kneehole door to match the rest of the hardware. I have the hinges soaking in lacquer thinner now to remove the lacquer coating. What should I soak them in next? Vinegar?
robliles
David, probably any acid (vinegar, lemon juice, etc.) will work to age your brass hinges. There are also numerous commercial solutions that will do the same. I use a product called "Brass Ager" that I got through Amazon that works really well and really fast. One thing I would recommend is to coat your final finish with lacquer or it will rub off.
