I've got a heavily used Hitachi 50AE brad nailer that came along with another purchase. I finally got around to testing it this weekend and discovered it's got a problem with depth adjustment. I can't turn the depth adjustment knob (it's jammed somehow) and, even though it appears to be on it's lowest (deepest) setting (when you press the tip against the wood it goes all the way down) the brad, when fired into a standard 2/4, stands proud of the surface about 1/8" of an inch.
So.... Can it be easily fixed? Is it worth it? Suggestions as to what the fate of the tool should be? I've got a newly reconditioned Bostich brad nailer so it's not a big loss... Thoughts/Advice?
