hardware storage?
I need to sort out my hardware, too many boxes around, can't find screws or nails when I need them.
You know the drill...
So I'm thinking two 24x48 inch cabinets on french cleats so they can be moved if needed.
3/4 birch ply shell with 1/4 birch ply dividers and drawers.
Something along these lines.
Question is how deep to make them?
6 inches? 8 inches? 12 inches? My first thought was 6 but now leaning toward 8.
attachment.php
TENdriver
TENdriver
Mike, Sorry I can't add to the discussion on depth, but since fasteners can get a little heavy, have you considered going smaller to cut the overall weight? A little more modular and portable might come in handy.
KenOfCary
I might want to do something like that eventually, so very interested in this discussion. Currently my screws and fasteners are mostly stored in those ziplock containers that are sold in grocery stores for storing food stuffs. They are cheap and stack well - they also have a place to mark what is inside them.
The other advantage is that they are portable and can be brought next to the project you're working on. An advantage and disadvantage as I sometimes forget where I last put them - did I mention I'm somewhat disorganized. When I am organized these work well and stack well - I just have to sort through the stack to find the size I'm looking for.
Please let us know what you finally decide as a solution.
Weight is why I ask 6 or 8 inches deep.
The drawers will slide out without runners,
I have a toolbox with drawers made this way and they have held up well for 30 years.
The bottom two large openings will be doors for box storage.
I can can build a small tote to hold a few drawers for off site work.
Jim M.
Woody
How about making a sample drawer of each size, then choose the one which best suits your needs.
Phil S
Phil Soper
My storage boxes range from 1 1/2 to 4" deep
I use a Lista cabinet that I was given. The drawers are 24 by 24 and have super strong slides - more than 200 lb rating
The inserts are from a third party I found on Ebay - search Lista drawer inserts
Here are some photos - I have ten such drawers and need more
The blue inserts are 1 1/2" deep. The red ones are 3" deep
attachment.php
attachment.php
attachment.php
attachment.php
I think you'll find 6" to be plenty deep for a single compartment drawer. If you go 8" I would divide each drawer into 2 compartments. The other thing is make the drawers shallow enough to get your fingers all the way to the bottom. Think about the size of your hands and getting a single brad off the bottom.
HMH
Heath Hendrick
Similar to Phil above, I've had great success w/ surplus card catalog filing cabinets from NCSU. They routinely pop up on the State surplus sales for ~$50 or so, as technology has long since made the old-school card catalog somewhat obsolete.
On the (2) I have, the drawers ~18"x24 full extension, and rated at 150# per drawer. I have 1 drawer dedicated to wood screws, 1 for metal, 1 for bolts, 1 for nails, etc. The dividers that bisect the drawers are sized almost perfectly for the width of a box of nails, as well as those plastic screw bins as it turns out.
Good luck!
Mike,
Here's another approach. I use several of these Store House Storage Boxes from Harbor Freight (currently on sale with a coupon for $5.99 each) that hold quite a lot of stuff. You can easily make a cabinet with simple 3/16" tempered hardboard shelves and slide these into place. I use a couple of them for screws, bolts, electrical connectors and fuses in my travel trailer.
ck1999
My mother in law makes alot of chocolate cakes. I have been stock piling the cocoa containers for while. They work great for holding hardware. However, like Bill mentioned trying to get something out near the bottom isn't easy. Shallower would be better. I have drawers that are the same height as containers and also a tote that holds about 16 I think. This way I can carry what's needed.
koslonc
I made a rolling cabinet for the Harbor Freight containers like Rob was describing. It holds 10 shallow containers and 6 deep containers.
attachment.php
Graywolf
Board of Directors, President
Richard
So Mike I'd think like others here that you'll be happier with the Six inch drawer and the shallow part is important getting your fingers in and out of a fastener box can be a hassle.good luck and I look forward to seeing your results.
ck1999
Jeff,
I have been looking at building something like that. How do you like those bins? I was looking at the stanley ones but the sections seemed small. I was looking at the 014725 trays. I was looking more for nails, screws, etc.
LeftyTom
Tom
I like these good ideas. Lots of my screws are stored in the boxes they came in, which can be a durability issue.
Bumpy
Frank
Look on Amazon, you can purchase pre-fab nut and bolt bins , 72 compartment for around 125.00.
Thee is an enormous amount of weight when you start filling the bins. Not sure a French cleat will hold up when full.
I utilized a wood base with 2- 72 compartment bins. It is attached to the wall, but not "hung" on the wall.
Good luck.
This has to hang on the wall, I don’t have room for anything on the floor, I don’t have room for a roll around.
i have some plastic bins and they are ok but starting to crack from age and less than ten years old.
i guess I’ll go with the 6 inch depth.
the bottom of the case will be sitting on a brick ledge so I can’t see a problem with weight.
NOTW
Notw
I made a cabinet similar to what Jeff did that holds 6 of the harbor freight organizers that hangs on a french cleat, works well for me
koslonc
Jeff,
Chris, I like the bins - especially when you consider the price. If you buy several of them, you can mix and match the various sized compartments across multiple bins to create the configuration you need. My only complaint is the big sticker they put on the clear lid as it obscures the contents in the bin. The stickers are not easy to remove cleanly.
I use about 6 of the bins for various size nails and screws. The rest hold other miscellaneous hardware and small parts.
MarkE
My cabinets (from Phil S.) are on cleats (metal strips) and loaded up with fasteners. Other than some sag in the particle board shelves, they don't seem to have any difficulty holding all the weight.
attachment.php
attachment.php
I also added the jar storage underneath. Jar lids are screwed to the underside of the small boards that slide into the 'T' shaped holders that are screwed to the underside of the cabinets.
attachment.php
attachment.php
Looks like you operate on the same theory I do. When I need a screw I buy a box, next time I have it.
Now I need more space to sort them.
