hand saw filing
creasman
File size depends on the TPI (teeth per inch). Triangular is the right file to use. You can check the chart on the spec tab here. That site is also a good source of files.
Rwe2156
DrBob
Be sure to buy good files. Lie Nielsen used to sell them. I don’t know where to get them anymore.
creasman
I've bought most of my files at tool meets and estate sales. Note, these are old, vintage files that are new or lightly used. These are usually American made files (Nicholson, Simmonds, etc.) and of high quality. Some of these brands are still around, but sadly the quality has gone down.
For purchasing new files here are a couple of resources. I don't have first-hand experience with either, but would not hesitate to order files from them. They are companies that make quality products and explain why they sell the files they do. These files are all foreign made.
Curious what other sites are recommended.
ScottM
Graywolf has taught several great classes on hand sharpening saw blades. Reach out to Richard. I am sure he would be glad to help.
Saw Filing--A Beginner's Primer
What Size File to Use
The next thing that you need is the proper file for the job. You should seek to buy the highest quality file that you can find. Avoid "bargain" files that are made in India or China. The teeth are not hard or durable enough to sharpen a quality hand saw. While they may seem attractive due to price, they will only waste your time and money. I use Nicholson brand files which are available in the maintenance section of this web site.
You should seek to use the right size file for the job. In general, saw filing files common is four tapers: Regular, Slim, Extra Slim and Double Extra Slim. There is a lot of mystique and confusion about what size file to use for a certain size saw tooth. The bottom line is that you should use the file which is not too big or too small. You should be able to easily see the teeth when you are filing. In addition, when each edge of the file is used, there should be no significant over or underlap among the three edges. If you use a file that is too small, you will use the same middle section of each face, which will be dull right where you need it to be the sharpest. Near the middle of each face is where the cutting edge of the teeth is sharpened. If you use a file that is too big you will not be able to see the teeth. Also, larger files do not come to as sharp an edge as smaller files. If you compare the edge of a 7" file with a 4" file, you will see that the edge of the 7" file has almost a 1/32" "flat" on the edge. Compare that to the edge saw of the 4" file. It comes to almost a knife edge. It is no accident that shorter files as used to file smaller teeth. If all this in confusing, don't worry. Just use the files that are recommended in the table below and you will be all set.
File TypePPI of Saw
8" Regular Taper3-4.5
6" Regular Taper5-5.5
7" Slim Taper6,7
6" Slim Taper8
6" XSlim Taper9,10
6" 2XSlim Taper11-13
4" 2XSlim Taper13-20
Finally, many people make a big mistake when they buy a saw file in thinking that it will last forever. You are only wasting time and producing dull teeth if you try to extend the life of a file. Each file has three cutting edges. The rule of thumb I use is that it a saw is really dull requiring teeth to be reshaped and filed, plan on only using one cutting edge per saw. If the saw only need a light touch up, then you may be able to get two saws sharpened per cutting edge. If your file makes a loud screeching sound when you use it--it is telling you that it is dull and that you should switch to a fresh edge. Saw files are so inexpensive, that there is no reason to try to use a single file to sharpen 10 saws. Use the guidelines above, and you will get the maximum benefit from each file. To remember which edges on a file are used up, I lightly dress the dull edge of the file on the grinder, removing the cutting teeth from the extreme edge. This will remind you that edge is used up and prevents you from trying to use it beyond its normal life span.
Dee2
Gene
The link would be another "Resource" opportunity, please.
Chris C
I've been doing a lot of sharpening lately. I've found both Pferd and Grobet files to be decent... way better than the modern Chinese/Indian/Mexican offerings from Nicholson and the like.
Some tips on files for those not aware:
1. Files are a cutting tool, and just like a knife blade, plane iron, ax, etc), need to have protection in storage. Wrapped in a blue paper shop towel, or for small taper files and chain saw files, a soda straw will do the job if you have destroyed or tossed the original packaging.
2. To get a little more use out of a worn or rusty file, soak it in a strong citric acid solution. It will be good for rough work, but I wouldn't use it for fine work like saw sharpening. My success with this is about 60% to the good.
3. Being made of high carbon steel, files will rust quickly from sweat. Gloves will help control this, but a good handle that keeps your fingers off the file is the best choice.
