Well here are the results of the conversion of the GO490 blade to Byrd Shelix cutter head. As previously reported, the conversion was pretty straight forward. With the help of a neighbor, we pulled the bearings and repressed onto the new Byrd and installed the head. Did a few trial cuts after an initial adjustment and everything seemed good.
I started to run some QSWO through the jointer and started to experience some minor snipe. Initially I thought is was the usual "operator error" but came to realize that the outfeed table was out of alignment. Further attempts to set the outfeed table to the cutter head top showed that the Byrd rides slightly higher than the blade head. This was compounded by the fence bottom preventing the outfeed table to be adjusted higher. Solution was to remove the fence and file the bottom of the fence by the outfeed table to allow the table to adjusted to the top of the Byrd cutter head.
Result was perfect...no snipe.
Dan C.
Dan C.
