I'm looking for a good electrician in the Mount Airy-Pilot Mountain-King area. I'm in talks to buy a radial arm saw and I need to know if I have enough space on the box and/or what is involved with a 3-phase tool.
TIA,
Floyd
TIA,
Floyd
3-phase power is typically used in industrial/commercial locations. I do not know if your electricity supplier will bring 3-phase to your residence/workshop unless they can make a profit from it.
If you are intent on getting a 3-phase tool, you will need a device to convert single-phase 220 to the three phase feed for the tool. Several members ob here are using that setup.
Contact Harry's Electric in King.
Randy at Bretco electric. They rigged up my 3 phase 15 hp rotary converter and plenty other work. FYI, I asked Duke if they could run 3 phase to my house. A nice guy came and throughly evaluated the situation. Three phase to my house would have involved upgrading the lines from the main road through a bunch of neighboring properties. Pole location changes, etc. Said it would be expensive and time consuming to get neighbors to agree. So I went rotary phase converter.
TIA,
Floyd
That all said, though, my own personal feelings (so take such as one may) on 3-phase equipment in a single-phase shop is that it generally is not desirable unless you are planning to acquire further 3-phase equipment and because a lot of 3-phase equipment tends to have much larger motors than our typical single-phase shop equipment you tend to require more capacity in your panel to accommodate the larger motors and their peak startup demands (plus the power requirements of the converter). However, most of the industrial 3-phase equipment tends to be of better construction and quality than our consumer gear and used 3-phase motors (and the equipment, if within the consumer realm) tend to go relatively cheap precisely because using them in a typical small single-phase shop requires jumping through added hoops and further investment in equipment and electrical to generate the required 3-phase power, so they do have those pros going in their favor on average. If you only have a single 3-phase tool and do not plan to acquire more then consider using a solid state converter or VFD as you can save money and a VFD can be programmed to soft-start the motor to reduce the peak amp draw on startup. On the other hand, if you plan to outfit your shop with multiple 3-phase tools then it is often more economical overall to go ahead and invest in one large rotary phase converter, provided your panel has sufficient capacity to accommodate the much larger load, and install a small 3-phase subpanel and then distribute 3-phase receptacles radiating out from that subpanel, that way you are not having to buy multiple converters (one per tool) in the future. Only you know what your future intentions and needs may entail, so weigh such options as you feel appropriate.
