I'd use faced unless you plan to use an alternate vapor barrier like Mylar foil or poly. Even though you may not plan on conditioning the air, temperature differences could cause moisture to migrate into the insulation & condense, creating mold. The pegboard hooks shouldn't dig into the facing, but I'd maybe smooth off the ends going into the board just to be sure. A vapor barrier that's poked full of holes isn't much good.
