I love Forstner bits. The Freud bit I purchased last night from Home Depot is wonderful. The way it throws out the waste while it is drilling is amazing. However, I need a 35mm hole. Contrary to what some manufacturers claim, 1-3/8" and 35mm are not the same. There's at least 0.020" difference. Now, this is woodworking, and that small difference shouldn't matter. Right? The hole I need to drill is for a piece that slides over a 35mm post. The hole I drilled with the 1-3/8" bit is not big enough. It's so close that I may be able to sand the hole larger, but even if I can, that will be a pain. I wish I had a 35mm bit. It's tough spending close to $45 to drill one hole.
Example
Example
