Upgraded these and now they're just sitting around.
The 1014 is manual speed adjust and comes with the pictured tool rest, a spur center, and a live center. 1/2HP motor. 5 speeds. This lathe runs true and without vibration, only reason to sell is I upgraded to bigger. 10 inch swing, 14 inch capacity if you hadn't already figured that out. Great for pens, ornaments, and the like. I turned a few cups and small bowls on it but I was feeling a need for more power.
The Ridgid 4331 is in good shape, used for about 3 years and not heavily. Second set of blades I put on it. I haven't honed either side so you could probably get a good bit of life out of both sides still. It runs well and turns expensive lumber into wood shavings and noise.
$150 for the lathe, $200 for the planer. I'm in Rockingham county.
