I figured I would start a new thread instead of continuing on the other thread which was kind of hijacked.
Daniel, this is how I flatten on my table. The ply under the slab is sacrificial. couple blocks and wedges to hold it in place. It doesn't take a lot of pressure to hold it and alternate the direction of the wedges. This was a 42" x 102" Sapele slab for a odd shaped table top I'm building for a customer. Once the top was flat, I flipped it and used the vacuum to hold it, but you can just wedge it again if you are not using a vacuum
If the board is really rough and twisted to begin with, I usually use a 3/4" downcut endmill as it can take a lot of material per pass. If it's fairly flat I use a 4" diameter surfacing bit from Amana however in figured woods, that bit can have tear out. It took 9 minutes each side using the 3/4" bit
