So I'm about to do my first attempt at something more than a box. Going to try to make a small bookcase for our tv room. I did my best to do it up in SketchUp and felt like I had it all figured out and though - "I wonder if I should see if NCWW have any thoughts or comments before I cut any plywood".
So I'm going to attempt to attach the SketchUp file and see if anyone feels like taking a look at it. I think it's fairly simple - just dado's and rabbets for joining the plywood. Then I was going to use some type of wood on the front to hide the plywood sides, and some type of molding for the top. For the bottom I was just going to put a kick plate and then cover that with the same molding that goes around the walls so it looks continuous.
I read somewhere that 3" is the normal height of the first piece from the floor, so I have a hidden shelf at 3" and then another at 5 1/2". I'm not sure if that's needed or not.
Also not in the file is the 1/4" beadboard that I will put at the back.
The first piece is the whole bookcase, the second is just the plywood, the third the wood front (I'm not sure what the technical name is for this part), and the last is my attempt at putting the plywood pieces onto a sheet.
