This is the finished cypress deck table hard at work on the shop porch. It will be moved to its permanent position on the deck at Kitty Hawk this week end. I had to try it out to see if it works properly. ccasion1
The design is loosly based on one Norm did some time back. I think he called it a Cricket Table. I came up with the top design. If you look closely you will see that the ring is made of a double series of arcs. The arcs are connected with pocket hole screws and then the slats are let onto the top ring. Finally the bottom ring is sandwitched to the top ring. Skysharks asked about working cypress. It works great. The only draw back that I can see is that sometimes its a little too soft and is easy to ding up and is a little prone to fuzzing up.Larry: Is that your design or from a plan? I really like it! As you know, cypress is my favorite wood.
