End grain chess board (pine/oak) finish?
TheyCallMeTex
Ben
Pine and oak, with a thin poplar border.
I was going to sand to like 400 and use wood conditioner/tung oil.
Sanding to a fine grit and using conditioner are the best guidance I can find for an end grain piece.
Thanks for your help y'all!
The lines aren't as tight as I'd like, harbor freight mitre saw LIES about it's angles :)
J_Graham
Graham
Look pretty good! Be sure you have lots and lots of oil (whether tung oil or another type) it will take more than you anticipate to flood the end grains.
TheyCallMeTex
Ben
I appreciate the help :) I did go with tung oil after some tests because I liked the effect on the pine, the amber really looks good next to the poplar border. (I wanted to do oak/poplar check pattern instead of oak/pine but I couldn't find poplar 2x2s.) I put a good coat of oil-based wood conditioner.
And also...bruh...it took FOREVER to sand the top down to 400 grit but MAN does it feel nice.
I think I'll do a few coats of the tung oil and then hit it with a couple of coats of varnish.
I really appreciate the tips yall. (Don't hate on my mitres too bad I blame Harbor Freight.)
Now I just need to find someone to carve me some chess pieces!
