Drill press repair....
LB75
George
It will never cease to amaze me how such a simple and cheap component can cripple a machine. I was using my drill press the other night and all was fine until after a few holes the spindle dropped out of the quill. I didn't hear anything break or any grinding, the spindle just dropped so that half of the lower bearing was sticking out the bottom of the quill. I shut the press off and when I grabbed the chuck the entire spindle pulled out of the quill.
After some head scratching I decided to take the thing apart and found the retaining ring at the upper spindle bearing had broken. No idea how it happened but it's fixed now, cost of repair was a whopping 1/100th of a cent for the new retaining ring (thanks to a Harbor Freight retaining ring assortment pack that I already had on hand).
ehpoole
Ethan
The real irony is that disassembly is seldom that easy when you actually want things to come apart.
Glad to hear you had a good Circlip assortment on hand to get back up and running quickly.
PhilCK
Phil
I was replacing the spindle assembly for a Powermatic 26 shaper with Grizzly parts (seems the G1026 is a copy) and you need 3 25mm retaining rings to hold the spindle in the proper position relative to the bearings. Turns out the indicated part in the Grizzly catalogue is a internal retaining ring when you need an external retaining ring for the spindle shaft. Grizzly sent me the proper external rings for free but blew a week waiting for the parts.
