When I started the recent changes (still in progress) the extra fields necessary for you to have DQ status where no longer visible and could not be entered. I apologize, the previous changes that I had made for that could not work with the new software.
For existing DQ members this was not a problem, but for people that could have become DQ, they weren't able to, if they hadn't already filled in the fields.
I fixed the bug that caused them not to be visible, and have placed them here they can be found (but not as obvious as I would like)
Go to "User Settings" > "Edit Options" and look near the bottom of the page under "Miscellaneous Options" The fields are prefixed with "DQ"
Because of this problem, I have delayed sending the updated DQ list to KlingsporColeman, there. So Please if you think you should be DQ and aren't then please go and enter the fields ASAP. I will only hold sending the list until 8/1/
Sorry Coleman
There will be no rush to process the list
Sorry Coleman
