Dave---------this thread has been haunting me:-D .
Just another view: If you make a segmented solid cylinder with x number of sides----at xdegree bevel (pending the number of sides) then mount that cylinder in a lathe. Turn it to a barrel shape inside and outside---those bevels have not changed------true or not?:eusa_thin
And--------if you have a flat stave pattern for outside dimension for width, cut the bevel along the arc of the stave pattern, by bandsaw or routerbit and template, before bending the same bevel should work.
Jerry
True, In theory, but not a real representation of the argument. Because of the curvature of a barrel you would need staves that where the same thickness as the radius of the barrel!
That is the question!! I don't think so! If you make a cylinder then the bevel as we have said is (360/#staves)/2 and they will make the cylinder, but as you bend the tops in towards each other to form the barrel then they become compound - don't they????????
