We're expecting our first child in November and I'm building the crib. I have roughly 2,000 bf of hickory laid out in my shop now and wow, there is a lot of beautiful wood to choose from.
I just have a few thoughts on the design of this crib; hopefully those of you who've built one can give some advice.
To start with, I really like the one Matt Cremona made and showed on his YouTube channel. He used mortise & tenon joinery and pinned the joints with brass pins to make it able to be disassembled and stored. My wife has showed me pictures of what she likes, which is straight posts as opposed to tapered ones and straight spindles vs. cigar-shaped. I'll gladly build what she wants; compromise is key, right?
I think I'll go ahead and buy the mattress to know exactly what size the frame should be. A search of mattresses on Amazon shows they're all roughly the same size, give or take an inch. It looks like the guideline says there should be no more than an inch of space between the mattress and frame, so I want to get this right.
Support for the mattress: I've seen slat-type supports and spring-type supports. Either way, it should be adjustable. Is there an advantage of springs over slats?
Joinery/Construction: I like mortise & tenon joints. Manufactured cribs, at least the one's I've seen, seem to use hardware and bed-type construction for ease of assembly. Do you have any input on how the frame should come together? I guess what it comes down to is making tight, square joints.
Spindles: The standard spacing is no more than 2 3/8" between spindles. I think it's better to not glue these but ensure they're nice and tight, to allow them to be taken out if need be. I'll get the frame built and then lay out the spindles using dividers.
Finish: This is a long way off but I'd like to hear some thoughts on this. I understand that all modern finishes (not containing lead) are food safe once they've cured and therefore baby safe. Although I doubt it's a huge problem, I still don't like the idea of a baby chewing or licking lacquer or poly. So I'm leaning towards shellac and wax. Also, ease of finishing a bunch of round spindles is a factor. Any input on finishes; is it even a big deal? I know this is getting into the weeds and may open up a can of worms...
I know there's a bunch of threads out there on cribs already but I just want some input on those little details. Thanks all for looking.
