How old is "older"?
What is the model number and serial number. You can probably look up the schematics and part number for the switch then start searching. I doubt that you'll find that particular switch locally, but maybe you can substitute another switch from a Big Box Store.
Hi all, I need a new on/off switch for my older Delta Unisaw , does anyone know if this can be purchased local to Durham ? or will I need to go online? any help is much appreciated, thanks !!
Is it a 220v saw? you can use any mag switch from grizzly for instance as long as the Amperage matches. What part do you actually need? I have a delta unisaw mag switch but the outer housing is brokenHi all, I need a new on/off switch for my older Delta Unisaw , does anyone know if this can be purchased local to Durham ? or will I need to go online? any help is much appreciated, thanks !!
If you have to go online, here are a couple of places you might want to try:
eReplacement Parts
Renovo Parts for Delta and Rockwell
