Hi All,
Hoping someone with the same saw might have some insight or can look at their saw...
A few weeks ago I heard a loud "clank" from the dust collector while using the table saw. I immediately shut off the table saw and dust collector. I initially thought that the piece of pine that I was ripping had lost a knot, but found that the nut (part #141 on the saw diagram) on the blade tilting mechanism had "fallen" out of the trunnion.
This is the diagram: http://www.searspartsdirect.com/par...rtsdirect.com/lis_png/PLDM/P0110069-00002.png
I haven't used the table saw since then and finally got around to attempting to repair the saw this afternoon. I can see where the nut came out of the trunnion and I am able to place the nut back into the trunnion, but can't see how it is to remain in place. The nut appears to have a groove cut in it and the parts diagram lists that an o-ring goes on the end. Although I am at a loss as to how a o-ring can keep the nut from falling out of the trunnion.
I'm wondering if there is more to this setup than just a simple o-ring? Any ideas or would someone take a look at their own saw?
Thank you,
Zach
Thank you,
Zach
