Delta 22-580 Planer Won't Feed
LeftyTom
Tom
Yes, I waxed the tables. So this isn't an easy fix.
Powers up, belt turns on one side, gears turn on the other side. The chains, however, do not turn.
Can I fix this?
LeftyTom
Tom
Aha! Perhaps the speed switch is getting finicky. I tried changing speeds, while the planer was running, no dice.
I post this, go back turn the planer on, and try the speed switch again (holding my mouth in the right position) and the feed rollers are hungry.
bob vaughan
Bob Vaughan
A worn pinion gear (1343903) is the first place I'd look.
There could have been a snap ring broke and the key slipped out of its keyway.
There are lots of various little things that can cause that symptom.
