hey guys I built a deck about 2 years ago the base structure is very strong 2x10’s on 16”centers on a double 2x12 beam let in to 6x6 posts In short it will hold a lot of weight.
I wanted dry storage under the deck… so I covered the floor with 1\2 inch treated plywood\with 30# roof felt then screwed 5\8 treated decking on top making sure that the growth rings were facing down to avoid any cupping about 6 months latter I notice that we had a problem the board were cupping against the growth rings:BangHead: :BangHead: :BangHead: (lesson learned you must raise the decking off the plywood surface and leave a 1\4-1\2” air space to allow for drying ) I put the decking in a herring bone pattern it was great at first now we got a eye sore as the LOML states quite freq :slap:
my problem is that I don’t have the clearance at the sliding doors available to raise the decking to allow for the air gap so I was going to replace the decking with composite ….big bucks plus I seeing all kinds of problems with mold and scratches cracking etc on the internet…. so my idea is to replace the decking with tile that would not be affected by water..it would stay cool in summer just wondering if any of you guys heard of or seen it done before?....:eusa_thin I am a little concerned with movement and freezing I would cover the plywood with concrete backer board set in thinset .... yall think that will work
