Hey folks,
I've picked up enough knowledge from this site, outside of general woodworking, to know that several of you are pros in the construction field as well, and though I'd ask some collective advise on an upcoming home project.
For a little background - we moved into our current (forever?) home roughly 18 months ago after searching for some time for either land to build on, or the "perfect" existing home w/ access to acreage. We were lucky enough to find our place at a great price, needing a little work here and there to bring things up my standards, but I kind of enjoy that side of things anyway, (I'm a structural engineer by trade), so it has worked out well thus far.
I did a thorough inspection prior to purchase, and had a list of projects that I knew needed to be addressed at some point, one of which being the crawl space, (damp, dirty w/ an existing vapor barrier in need of replacement). Fast forward to last fall, my wife mentioned a musty smell in her reading nook off of our bedroom, that I initially didn't think much of, but one afternoon a few days later, while replacing the HVAC filters (in the afternoon vs. at night which is usually when I find time to do such things), I saw daylight when I opened a small return grill in that room - no bueno. I got into the crawl space, (of course at the opposite end of the house from the access door, and noticed that the duct had fallen away from the register. I fixed that, and went through the rest of the ductwork the following weekend, taping several other areas I found that were partially separated, (learning to wear gloves when working w/ foil tape in the process - that stuff is sharp!)
In addition to the seam issues mentioned above, the ductwork itself (flex-duct) was heavily condensated in some areas, and "heavy" like moisture was trapped between the inner duct and the insulation itself, which I assume to be from the "blow-by" of the leaking seams getting between the 2 layers and condensating internally. As is typical, the first floor ductwork is under the floor, and I found all sorts of construction debris i the duct when reaching in from above as well, so in light of all of the above, I've decided to replace the first floor ductwork completely in the Spring, (when the weather permits going w/o HVAC for a few days).
Before I replace, (or have replaced), the ductwork, I also want to trace the root source of the condensation. We have a relatively large home, w/ approx 2000 sq. ft of crawl-ranging in height from 5' to 2.5, w/ typical foundation vents. I've installed a couple remote humidity monitors at opposite corners of the crawl, closed the vents, and put in a few box fans for circulation over the winter, and have noticed that the humidity levels are still pretty high, even w/ the low ambient winter humidity, and spike after a rain, leading me to believe that there may be some benefit to routing the downspouts away from the foundation as well.
To resolve all of the above, and also to help w/ making the home more efficient, I am heavily researching encapsulating the crawl space, w/ new rigid insulation on the inside face of the CMU, and pulling the batt from the joists - does anyone have any experience in this arena?
A quick search for "order-of magnitude" pricing to encapsulate a crawl-space quickly led me to discover, that this will be a DIY project for the most part, (not that I blame the contractor's pricing - hanging out in someone else's nasty crawl-space for a few days doesn't sound like much fun to me either).
My proposed project sequencing is as follows:
1. Trench and run lines to re-direct the downspouts 10' or so away from the foundation.
2. Remove the existing flex duct in the crawl space, and replace w/ new.
3. Seal the existing foundation vents, and install 2" RI to the inside face of the CMU, (leaving the req'd/ 3" termite inspection gap at the sill plate). I'll either pack the rim joist w/ batt, to include the termite inspection barrier, (the batt can always be pulled back for inspection, or look into having the cavity above the sill insulated w/ spray-insulation, and adding in a removeable 3" strip of RI to cover the inspection requirements.
4. Pull the existing batt between the joists, and seal all penetrations through the floor.
5. Line everything w/ a new 10mm vapor barrier, to include walls and piers.
Please forgive the long post - just trying to get all of the pertinent info in. If anyone has gone down this road, either as a homeowner or as an installer, I'd love to talk to you! Also, I wouldn't mind a "sanity check" from the group to make sure I'm not way over-doing it here. I understand that vented foundations are, and have been, around in the South for decades, but I also know that construction methods and bast-practices evolve, and am of the "if you're going to do something - do it" camp. Coupled w/ the above, I do have 2 young boys, on of which is asthmatic due to pre-maturity, that is heavily weighing my decision making here as well.
Thanks guys - looking forward to the advise.
