Wow, #5 is .038 wide x .016 thick that’s way smaller than I thought! I’m guessing they break pretty easily if you make a wrong move…or try to cut too thick or too hard wood.Blade size to use is determined by wood thickness, wood type and pattern.
We used 1/4” plywood with a #5 skip tooth blade with our practice cuts yesterday at the club meeting.
I find #5 and #3 my most often choice of blades.
Twisting during a cut is more often technique than blade choice.
I recommend The Scroll Saw Workbook for people wanting to learn.
Blades break when you try to force them through a turn. Just slow your feed rate and allow the blade to cut through the turn.Wow, #5 is .038 wide x .016 thick that’s way smaller than I thought! I’m guessing they break pretty easily if you make a wrong move…or try to cut too thick or too hard wood.
