Rob, that should work just fine! The DC might momentarily try to start when you flip the SPDT switch (unless you are really quick :-D ), but that shouldn't be a problem.
Alan, I realize that for the short time it takes to move the toggle from the On position (through the center Off) to the Service position that the power to the control relay drops and the DC contactor will start to close. It should just be momentary and I don't think it will cause any real problem -- on the plus side, this sequence does break the Red wire from the photoeye before making connection to the hot side, thus eliminating any possible harm to the photoeye circuitry. And it insures that the bin can be serviced under lighted conditions. Once complete, the switch goes back to the On position and the DC can start.Rob, that should work just fine! The DC might momentarily try to start when you flip the SPDT switch (unless you are really quick :-D ), but that shouldn't be a problem.
Sounds like an interesting option to the 7 watt candelabra bulb (which puts out a low level of light similar to a candle flame). They cost about $0.20 each. The photoeye didn't come with any sensitivity specifications, but I have tested my mockup of the circuit with a 6" clear plastic jar across the beam and I dumped saw dust into it -- it tripped the circuit only after there was a pile of sawduct blocking the beam (the dust in a stream did not trip it).
How expensive would an LED array be?
So here is your challenge -- light source that is reasonably collimated (parallel beam) that will shine through a 3/4" diameter hole. In lieu of a "wall wart" transformer AC-> DC power supply, is it cheaper/easier to make a small power supply integrated with the LED electronics? Alan's latest unit fits in a standard waterproof PVC LL or LR conduit elbow with a single wall plug for power (Photoelectric unit needs 110V power).
