Phil, what about installing light by your back door, that is hooked into the power at the compressor? I have something similar for my phase converter. In my instance I installed a red light bulb in the shop that is wired into the power feed for the phase converter. Whenever I leave the shop, I can see if the red light is still lit - reminding me to turn off the converter. You could make it a low voltage LED light if you wanted to run small wire, and feed it by a small transformer wired into the power switch to the compressor.
