I'm building one of Isaac Youngs' shaker wall clocks. I scored this mechanical movement for a song on eBay, 20% of retail, but when I got it, I realized that it is a front-mount movement, i.e. it will be screwed into the dial. I wasn't anticipating this, and I had initially planned the clock to have a paper dial backed by some thin stock, but now I obviously need to do something different. I increased the thickness of the backing board to 1/4" but I'm still trying to figure out the best way to mount the movement to the dial. Requirements are that the screws can't be seen from the front, the dial backing board can't be any thicker (the hand post needs to poke through a set amount), and it should be easily removed for servicing. Any thoughts on how to make this work? I initially thought, threaded brass inserts, but I can't find them in 1/4" lengths for my application.
Also post pics of your nice clocks if you haven't already! I've really enjoyed looking through the older threads of clock builds.
