I recently had surgery so I was laid up unable to do much other than surf the net. And....... of course I ended up in Aliexpress. I ended up buying some long nib markers and pencils (like 10 bucks for 5) and a couple of offset 1/4 drivers and finally the dowel maker. It was like 15 bucks with postage for the dowel maker.
1st Impression. The block is nicely finished Aluminum about 1/2" thick - the cutter is carbide insert.
The adjustment is you take out the out side screw move to the hole you want and then put the screw back in and ready to go.
I cut a square-strip of maple and mahogany rounded the tips as a starter, stuck the other end into a cordless drill and went at it.
I tried the fast rpm and slower rpm setting. I found it works better at slow, less tearing.
Then, I just stuck a piece of sandpaper in the vise and sanded it smooth.
Although the holes are metric, after sanding it make a near perfect Imperial dim.
Thoughts - it is a pretty cool tool for 13 bucks and I will use it from time to time when I need dowels. I would give it 4-4.5 stars, definitely does it is promises, though pretty manual. Worth the purchase.
Thought I'd share
Thought I'd share
