Cherry Headboard
Jeremy Scuteri
Jeremy
I set out to make a bed about 4.5 years ago after my wife asked for a simple headboard. I designed a bed in sketchup which took a while to do and started building it about 5 years ago. Then we moved and I built the new shop which really took a long time. My wife bought a headboard several years ago at this point and this work in progress has been sitting collecting dust.
Time for a course change (back to the original destination, haha). Headboard request --> bed design and build --> back to a simple headboard
Starting lumber
Marking out parts
Rails and stiles on the router table using a shop made jig.
Have a frame. Just need panels.
Tenons will be at the ends to attach to legs
First panel in place
All 3 panels.
Stock for legs
Ripped on the badsaw
The rail and stile set allows for full size tenons which is nice. The tenons can be longer than the depth of the groove for the panels.
Mortises in the legs
Tenons for the legs
Getting some help putting on some oil. This was March 2016. Time flies.....
Panels in place
Top "cap"
with oil
another pic of the top cap
This is pretty much where progress stopped for several years.
Jeremy Scuteri
Jeremy Scuteri
Jeremy
Finally got back to it. I sprayed on some General Finishes Polycrylic that I got a while ago. It went on very nicely.
back side
Legs glued on
Used dominoes to put the end cap on.
A spacer allowed me to get the proper alignment
Glued in place
Glue up is done.
Mounted with a white oak french cleat on the back
All done. Makes the guest bedroom look nicer.
Very nice work Jeremy! But next time you may want to give the oil a little longer to dry, to avoid any finishing issues with the top coat :)
Really like the end cap detail.
KenOfCary
Very nice piece. The finish came out great - it will only get better with time.
Bryan S
Bryan
Looks great.
Now why do the wives like to cover up such gorgeous cherry with those flowerdy little pillows?
JohnW
Thanks Jeremy. My wife thinks I occasionally take too long on a project. Well, now I can show her how long it took you and try to explain that it is normal.
BTW, Headboard looks great.
