Back story - hampton bay ceiling fan - 3 speed with light kit. Light and fan operated by separate wall switches. Fan stopped working but light was working OK. I noticed the fan pull chain switch was loose so I tightened it up and then fan worked. As part of a remodel I replaced the toggle wall switch with a 3 speed switch. Fan not working now but lights are OK.
There is power to the switch box. Wall switch shows continuity through switch. There is power at the ceiling when the fan wall switch is on the high stting. I think that narrows it down to the fan pull chain switch or the fan motor. I pulled the light kit off and have access to the fan switch wiring.
Where do I go from here - I'd like to verify that the 3 speed pull chain switch is OK but not sure how. If that is OK then I need to check the fan motor.
I would appreciate any thoughts or suggestions you may have.
Rick
Rick
