Candidate for Restoration?
1075tech
Tim
Hopefully worth the $15 I paid.
No maker that I can find. Just "MADE IN USA". Measures 14"x2½".
It's complete with a couple of non original screws and washers.
creasman
Looks like either a Stanley No 5c, or else a clone of one.
1075tech
Tim
After some rudimentary cleaning, I find that it is a Miller's Falls 814C. It appears to be some variation of a Type 1. Possibly a 1F from the late 30's or early 40s
NOTW
Notw
some more info on the 814C
If you are ever on Craftisian.com look around for HokieKen, he is a collector of Miller Falls handplanes and a wealth of knowledge.
Disassemble, Wire brush it, then soak the metal parts in phosphoric acid diluted to 20% for 4-8hrs. Then use, a urethane wheel to do final clean, then move to the normal prep you do to the plane and you got it.
1075tech
Tim
It appears to be just surface rust. Probably sat in someone's damp barn or basement for a bit. I don't see any pitting.
It should clean up nicely.
1075tech
Tim
If it was in better shape I'd buy it. I am starting to gather a set of MF planes.
I basically want to get it usable. And use it. There's something relaxing about watching a craftsman using a plane. The sound it makes.
I'm no craftsman, but I want to learn more. I like using the older tools.
