Building a Chevalet de Marqueterie
creasman
Many of you are aware from a previous post that I am building a chevalet. I want go into details of chevalets, their history and use. You can read that in an excellent article by Patrick Edwards. I'm mostly finished at this point so I thought it would be a good time post some pictures of the process and result. My next step is to disassemble the main sections and seal the wood. Often chevalets are left unfinished, but I want to give the bare wood some protection. I'll post some resource links at the end.
The first step was to make (or find) all the parts. You can make these out of any stable hardwood. I chose European beech, a traditional option. I through in a splash of purple heart to give my "chevy" a more stylish look.
Most of the non-wood parts are off-the-shelf items you can find at a hardware store. There are a few, however, you have to fabricate or have a machine shop do for you. I chose to make these as well and that is the contribution I made to the SAPFM article in the most recent (2023) APF Journal.
As you can see there are a lot of wooden parts to cut and shape. I was curious and counted around 30. No two are identical. Needless to say, I followed a plan and didn't try to work this out on my own. That would have taken considerably longer. I started last Spring, took a break to complete another project, then resumed the work in January.
I began by assembling the seat. It consists of two legs, a stretcher and the seat. A chevalet is like a tripod when complete. The seat is attached to the main post later. That gives it stability. Anywhere I used through tenons that were visible I used wedges of purple heart to add contrast. The front leg is square to the seat and the back leg has a six degree splay. Note the bolt in the last photo used to temporarily clamp the stretcher to the front leg. This is also a through tenon, but it is eventually covered when the front post is bolted to the seat.
The post is just an upside down "T". I used a double tenon with glue and wedges to secure the post to the base. No clamps are necessary as the wedges hold the joint tight as the glue sets. The purple heart here is foot pads when in use. The last photo shows how the post and the seat will be joined. I've added the moving jaw to the front of the seat at this time.
The column and pressure bar are the next parts to assemble. The column fits into a recessed mortise in the seat and is bolted up through the seat. I used 1/2" bolts with square nuts. In most cases the square nuts fit into cavities so they cannot turn and are unseen. The pressure bar will eventually be held in place with a 3/8" steel pin. Note the spacer blocks and through bolts that hold the front post to the seat assembly. Removing these two bolts separates the two.
Next up is to assemble the foot bar. The bar is held in place by a retainer. A chain running through the seat connects the pressure bar to the foot pedal. As you press down on this bar (with your heels) it pulls the pressure bar down, causing the front jaw to squeeze toward the back jaw. This action holds the work in place as you saw. Roller bearings moving over a wear plate keep the action smooth.
The cross bar and guide assembly is next. The bar slides through a mortise in the post with a clamp block to hold it in place once adjusted. This design allows you to use multiple sizes of saw frames should you choose. Draw boring and pegging the joints eliminates the need for clamps as the glue sets. Pegs from purple heart make it clear how the joint is made. The brace does have a couple of hidden screws.
While it might seem like an unstable design the cross bar does not move once the clamp plate is secured. The two brace pivot blocks (one on each end of the guide bar) allow for adjustment of the saw frame -- one vertically and one horizontally.
Last part to assemble is the saw frame, itself. It attaches to the guide rod assembly. The double-rod assembly allows the saw three-way motion -- front/back, up/down and left/right. The top rod pivots while the bottom rod slides through guide blocks. The French came up with a very clever design. The ornamental knob is not a handle of any sort. Instead, it is pressed against your shoulder as you tighten the saw clamp. It allows you to keep tension on the frame until the blade clamp is secure.
These are a couple of photos showing the fully-assembled chevalet. The front and back jaws each have an extra, sacrificial jaw with a "V". Over time these will need to be replaced as the saw occasionally cuts into these. Using the saw takes a bit of practice at first as it requires three separate actions. You press down with your heels to hold the work piece, rotate the piece with your left hand and work the saw with your right hand. It's like that trick where you're asked to rub your stomach and pat your head at the same time -- hard at first, but easier as you get the hang of it.
drw
Donn
Jim, the chevalet looked like a complicated puzzle when all the parts were disassembled, but even assembled it still looks complicated. That said, the workmanship is absolutely beautiful and I look forward to seeing the amazing work you produce with your new chevy!
Graywolf
Board of Directors, President
Richard
A video is going to be a must, congratulations Jim I know this an undertaking.
Wilsoncb
Williemakeit
That’s a thing of beauty. When I read the post title I can’t help but think of an old Steve Martin routine from the late’70’s. It’s like those french have a different word for everything. ”HE SPOKE FRENCH!”.🤣
creasman
creasman
Forgot to add the resource links I mentioned. This will be useful for anyone attempting to build their own chevalet.
  • Joe McGlynn created a SketchUp for a chevalet following blueprints purchased from Patrick Edwards. His plans cover the woodworking. He assumes you are buying Patrick's hardware kit, which he no longer sells. You can download and use Joe's SketchUp for non-commercial purposes from his site.
  • When I was taking classes at Patrick's school I had the opportunity to take measurements of the sliding rod assembly and blade clamps. @Dave Richards (our local SketchUp wizard) graciously turned these into detailed specs. I've attached these to this post.
  • David Clark, Patrick Edwards and myself collaborated on an article that appears in the 2023 issue of American Period Furniture. This is the annual journal of SAPFM. The article covers making a chevalet in detail, but is available to members only at this time. I will seek permission to add this to our site resources once the time restriction has elapsed. David used to sell kits but is no longer doing so. Of course, you can always join SAPFM here and have access now. The plans here are slightly different from those created by Joe, but either will get you to the same end result.
Regarding a video, we shall see once I reassemble and get it tuned up. I've been so focused on the tool that I haven't decided yet what my first project is going to be.
Rwe2156
DrBob
I‘m familiar with these. I’ve heard people say they are more accurate than a scroll saw.
Really nice work.
No hide glue? 🤣🤣
creasman
creasman
Really nice work.
No hide glue? 🤣🤣
Thanks. They are very accurate in the hands of a skilled craftsman. I'm told you have to go to the very high end scroll saws before there is a comparison.
For the record, I did use hide glue on the pegs and some of the more visible glue joints. Mostly it was Titebond, though.
tghsmith
tghs
looking really great,, I thought about building one 30+ years back.. with the correct blades your can sandwich brass sheet in the mix!!!!
creasman
creasman
I decided to put a couple of coats of poly on the chevalet to protect the wood. Traditionally, these would probably have been left unfinished. This required a complete disassembly, finishing and then reassembly.
After getting everything back together I made the final adjustments this evening so the cut is true. It's tuned up and ready to go as soon as I find a marquetry project.
Wilsoncb
Williemakeit
That’s quite the beautiful contraption. I’d put that right in the middle of my living room when not in use.
I imagine this is like the high end weaving looms, you have to take your shoes off to work so you don’t mar the finish…
as per usual very nice extremely skilled work.
creasman
creasman
It's funny you should mention that. Part of the tuning process is to saw a key out of a block of wood. If the adjustments are correct the key will slide out either side without getting stuck. After I'd finished I found myself brushing the dust off the foot pedals. I thought, "This is silly! It's a tool and it's gonna get dusty."
