Well looking at my last 3 WIP posts I get the sense that they are a bit boring or not very useful(4replies/910views). So with this one I'll be short and answer questions if they come back.
In the past I have used Ball and Ball Brass for some brass pieces. They have downsized and their inventory is not what it used to be. In many cases you have to wait "until the set up for that piece of brass" to be stamped out is on the production floor. Wait?
The piece I am showing below is 16.50 and 8 bucks shipping. This is time consuming and the convenience of purchasing the brass is worthwhile in most cases but I decided to make it up and be done. After all, I call myself a rifle builder and this includes making all the brass parts from sheet brass.
Here's how I do it:
Solder an example to the sheet brass stock. Notice the nail holes in the template? These are critical to use as indexing points as you file later. I drill out as much as possible once I screw the sheet stock to a piece of hard wood.
I don't have a scroll saw so I cut out the plate with a fret saw and then use needle files to get close to the shape I want.
Once I have the shape close I heat the pieces and separate them. I forgot to mention, I anneal the brass before working it so its nice and soft. Later I will stiffen it back up before polishing and installation
Test fit on lock side. The other false plate will go on the other door.
That's it.
Here's how I do it:
That's it.
