Blade size and type
Tonyt
Tony
Bought a Craftsman 351.214000 bandsaw yesterday and want to order new blades. What size blade and what manufacturer do you reccomend?
JackLeg
Reggie
Size will depend on your use. I use mostly 1/4 and 3/8. Irwin makes good blade stock. I buy mine from the guys in Polkton, NC whose name escapes me at the moment!
Precision Saw Works is the company. Nice folks to deal with.
T
Tonyt
Tony
Thanks
What length though?
T
Tonyt
Tony
The rikon 305 is supposedly the same saw as the Craftsman 214000 so I'm going to order the 70 1/2 blade.
bob vaughan
Bob Vaughan
A little 'gotcha' detail on bands for that saw is blade thickness. You'll want to use .020 thick blades for best results since they will make that sharp bend around a 5" radius wheel a lot easier than the thicker .025 blades. A .025 blade will work well enough for 1/4" wide blades and under. Over 1/4", a .025 blade puts a lot of strain on that little saw's wheel and frame.
tvrgeek
You should be able to find the owners manual online and it will tell you the band diameter.
