Black Walnut Floating Top End Table
Jeremy Scuteri
Jeremy
11 years ago I bought some black walnut for dirt cheap. Note the piece on the far right. I thought that was an interesting piece at the time, but never know what I would use it for.
The bench is 60" long for reference.
Some cleanup
Crosscut on the slider
Then off to the bandsaw
Some resawing
Planning out the top, the void will be filled with epoxy
Filling knots with epoxy tinted black
Flattening another piece for leg stock which was too wide for my jointer.
Made a form for the epoxy pour
Metallic pigments
Parts planned out. I had some fun with the grain on this one.
I had to laminate some pieces to get the grain that I wanted and the thickness that I wanted.
The bottom piece is a left-right bookmatch.
Leg stock
The 3 show faces. The other face will go against the couch.
Jeremy Scuteri
Jeremy Scuteri
Jeremy
Sliding dovetails for the floating top
Cut some bevels on the edges of the table. Made a fixture to hold the stock on the sliding table. This worked well.
Dry fit
Decided to try pre-finishing on this project
Glue up
Floating top attachment points
Final resting place
I had a lot of issues with the finish, still not 100% happy with it, but it was time to move on. No exaggeration, I applied and sanded off the finish at least 7 or 8 times. There may have been a few curse words and temper tantrums.... :)
Beautiful work Jeremy, really like the epoxy pour on this one. Linking the full size image here for folks to really appreciate the detail (link to album)
index.php
What did you use for finish, and what caused the problems? Was it the finish over the epoxy?
Phil S
Phil Soper
Fabulous I have a similar piece of "what to do with" wood in the corner of my shop. Now I know
Thanks
gritz
Robert
I know finishing those materials with varying porosity would be a challenge for me. Nice piece!
Jeremy Scuteri
Jeremy Scuteri
Jeremy
First I tried wiping on shellac that was heavily diluted with denatured alcohol. I was getting really bad streaks and bubbles where there were little pin-holes in the epoxy (places where knots were filled, not the river-pour section). Eventually I gave up on shellac and moved to General Finishes Arm-R-Seal. I have used Arm-R-Seal several times in the past and have had good results wiping it on with a rag. I thinned it with Mineral Spirits, but I couldn't get it on without getting bad streaks (much like the shellac, so it is probably something about my method). I moved to a foam brush with Arm R Seal, which was putting on a heavier coat and the streaks went away, but I was getting bad runs and drips at the edges.
I even tried spraying the shellac and the Arm-R-Seal, but I would get TONS of little specks of crap on the piece. Some of the larger specks had a white color to them which made me thing about the last thing I sprayed (white enamel paint). Probably didn't clean the gun well enough.
Eventually I sprayed a light coat of Arm-R-Seal on the top, sanded the specks of crap off the top and called it done. Once the piece gets some use and I re-learn how to put a coat of finish on, I'll probably redo the finish on the top.
JohnW
Love the design and build pictures Jeremy. Like how you arranged the grain patterns.
I've had the same issues with epoxy fills. Depending on brand and formulation, epoxy requires special prep before finishing. Consult the manufacturer and see what they recommend. It typically includes waiting for the cure to finish, washing/scrubbing with water, and sanding to get level and add a bite for the finish to adhere. I just completed a natural log coffee table refinish and had several large areas that required epoxy fill. It takes much longer for a thick fill to cure than I expected. Had to wait a week to 10 days before the finish would go on without blush and pock holes. My shop was at around 62 degrees at the time. Turning up the heater would have speed things along.
drw
Donn
Jeremy, beautiful craftsmanship! Additionally, the entire project appears to be well-planned and well-executed. I have no insights regarding your finishing issues. I typically enjoy the building phase, but when it comes to the finishing, I am not a fan.
Mark Johnson
Jeremy, I had difficulties finishing an epoxy piece as well when trying to use poly. I had roughed the surface as required, but still had streaks and ton's of tiny bubbles. After stripping it all back off, I elected to sand the entire top to 2000 grit and applied Odie's oil which is more like a wax that hardens. It worked well, but I did not get as much sheen as I would have liked even with some buffing. Next time I may try either an epoxy topcoat (very high sheen) or Rubio Monocoat. Both seem to be widely used for river tables.
JohnnyR
Beautifully done Jeremy! How many showers did you take before you had it figured out in your head?
sawman101
Bruce Swanson
Just like Phil, I have a book-matched pair of 8/4 maple slabs in the corner. They are around 6' long, and I've not given much thought to their fate. So thank you Jeremy, for inspiration from your beautifully rendered table!
