Good afternoon all...I'm seeking some advice on design and joinery for these headboards and footboards I'm building for my daughters. The mattress will sit on a platform/case that will have drawers based on the design in FWW #240. Below is a draft of the design my wife likes. It is all poplar and plywood since she wants it painted.
I will be milling some trim to go under the cap and around the open panel areas, but that is not in this sketchup model yet. I was going to mill the posts to 2.5 x 2.5, then attach a 3/4" plywood panel. Over the panel I was going to apply the 3/4" "rails" and "stiles", and then trim those out.
Questions:
1. Should the rails and stiles be installed similar to a door, or how they are in the design be okay?
2. How would you join the plywood panel to the posts? My initial thought is to use glue and pocket holes that would be hidden under the stiles on the sides. I'm a rookie, but I'd be willing to try something else!
3.Should I just glue and brad nail the rails and stiles onto the plywood panel since I'm painting and could fill the holes?
Thanks all!
Questions:
Thanks all!
