When I made mine, I used a forstner bit to drill a shallow hole just the depth of a zero clearance insert blank (purchased on Amazon) in a scrap of plywood. I then used the miter gauge to guide the scrap and cut a slot in the center of the insert with the blade that I intended to use with it.
A little double-sided tape would ensure that the blank doesn’t rotate during cutting, but in my case, it was a snug fit, so I didn’t use any.
