Need Advice Bandsaw scorching
ashmatash
Ash
I have an old Delta bandsaw that I picked up from FB Marketplace. It was a good deal, but was "well loved" during its previous life in a machine shop.
I spent a fair amount of energy replacing the tires, blades, bearings and cleaning up the "gunk" left behind from years of metal cutting fluid build up. It was quite a mess to take apart, clean and put back together.
Now that I've got it running again but I'm running into an issue where it is scorching wood when I try to make cuts.
Below is an example of a tiny little cut I made and it went right to smoking after less than inch into the cuts.
The seller, who was a Bosch fan, included a few brand new blades. I recently swapped to a newer blade, hoping that would cure my ills, but the new blade burns every bit as bad as the old one.
Are these Bosch blades just garbage, or does anyone know if there is something else I should be looking at?
Charlie
Charlie
I don't see any "teeth" on that blade and it appears to be installed backwards. What little teeth there are, are cutting from the backside.
Maybe I'm missing something??????
Ricksmi
Rick
Yep the blade looks very dull and it is for sure running backwards, surprised it could even cut let alone burn the wood.
mkepke
Don’t sweat it - “there is no dumb question”
Unrelated but what was the previous owner cutting with the saw? Your comment about cleaning out cutting fluid gunk has me curious.
-Mark
A
ashmatash
Ash
Previous owner was a machinist, so I think it was cutting fluid residue...
The table top, blade guide and components below the table were completely covered in a thick black greasy substance that reminded me of the cutting fluid I use when drilling steel or iron on my drill press.
Had to break everything thing down and scrub it with Krudcutter to get the parts clean. Replaced the tires, the thrust bearings and added a fence... and then I put the saw blade on backwards as proof of my ultimate cleverness.
Roy G
Roy
I remember the first band saw blade I got. When I opened it out I noticed the teeth were on the wrong side of the blade. I was about to take it back and complain when the old light bulb went on over my head and I flipped the blade inside out. Voila the problem was solved.
Roy G
Henry W
Henry
It’s an easy mistake to make.
And some of us know firsthand how easy it is to make that mistake - not that I would ever admit to that publicly, not me ... never admit it and any potential evidence would now be burnt in the firepit - so no, never happened at my place!
Tom from Clayton
tom
Reminds me of when I worked at a breakfast cereal company and bought a couple of work shirts at the company store. Got them home and the pockets were on the inside of the shirt. Took them back and they explained amidst the snickers that the pockets are inside so stuff doesn't fall into the boxes of cereal. If you don't know you don't know.
I wonder if he was also a hunter. Sounds like he was using it for butchering. Any metal dust in the mix?
bob vaughan
Bob Vaughan
Or cutting aluminum, but that should have been obvious from the chips.
Years back I was given a band saw that was used for cutting meat. What a mess.
cyclopentadiene
The most fun is folding a band saw blade without poking yourself. I have to watch a video every time to fold them correctly I get lazy and just leave them fully open after changing sizes. Eventually I get irritated in that side of the shop and fold several at the same time.
Berta
Berta
I can fold a bandsaw blade. UNFOLDING….I just toss it away from me and let it do its thing. It understands to unfold without biting me.
ErinJ
Pat
Blade looks very dull and installed backwards as well. If you are not getting anything after the fix, try getting a different blade. Also, are you open to upgrading those guide to a band saw guide upgrade kit?
DSWalker
No need to go hide for a bit. I'll wager that everyone that has replied to this thread has done something similar. We all do it. I've probably got 3 or 4 of them... or more? Just laugh it off and keep making glitter. :) The people on this board are here for you.
