I have started building a treehouse for my boys. It is suspended between two large pine trees. The platform is approx 16' x 8'. The trees are about 8ft apart and the house sits on the platform between the trees.
I got the PT lumber from the BORG, and based on their specs, the whole thing should weigh around 2500lbs. (Not sure if they calculate that weight wet or dry).
So here is my concern. I used 5/8 by 8" galvanized Lag screws (5 on each tree) to support the whole thing. 2500lbs is a lot of weight and now I'm second guessing myself if the lag screws are sufficient for that weight. I could support the structure with 6x6s to be sure, but then it would be more like a deck than a treehouse. I would appreciate any thoughts about if the lag screws are enough to support the treehouse.
Thanks
-mike
Thanks
-mike
